HELP! '90 740 Turbo stalls when you put it in drive or rev.
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
1990_740Turbo
Post by 1990_740Turbo »
My friend's '90 740 Turbo Automatic stalls when he puts it into drive. He said it idles fine and revs fine in neutral, but if he tries to put it in D or R it stalls out. Cranks back up though in N or P.
Anyone know what this could be?
sseir39
Post by sseir39 »
What is the idle like? If it is slow and not using the accellerator, possible the ISM is not clean. Idle speed motor. Also check for hoses loose as this can change the fuel air mix. Turbos do go through hoses and leakage or a torn hose can also cause this. Air mass meter is another possibility.
First check the turbo hoses.
Dick
