Can I get some help finding a good site to order a new dipstick? It seems like mine is discolored and it is hard to read.
Is this common?
Oil dipstick hard to read
- Has thanked: 17 times
- Been thanked: 35 times
Common if you have moisture in your engine from condensation causing the dipstick to become rusty. Drive her hot and hard at least once a week and get rid of the moisture. You can find the dipstick on eBAy but Volvo changed them several times. I believe maybe there are 5 different ones and so if you change the dipstick, Volvo recommends you also buy the tube. This is a waste of money. Go to the dealer, pull your dipstick out and take it to their service department and ask them to match it....they'll bring out an array of dipsticks from different 850's and first few years of S/V70's. This is what I did after my dipstick handle broke off. I got a perfect match (but different part number that what I expected). Good luck!
Thanks, I'll head to a Volvo service department for a dipstick.
I have a hard time believing it could be moisture in the engine. I never run it that hard, but I never start it unless it is going to be driven enough to be fully warmed up. How should I run it hard? No matter what, it seems like my temp guage never moves. Maybe drive down the Freeway in 3rd gear for a while?
1998 Volvo V70 GLT
2003 Dodge 2500 Quad Cab Diesel
1966 Ford Mustang Convertible
1951 Willys CJ3A
2001 Lund Pro Sport
2007 John Deere 3120
1951 Willys CJ3A
2001 Lund Pro Sport
Since this is for a '98 V70 (and I just realized you posted in the '01 and newer section) I'm moving the thread to the appropriate place on this forum.
Btw, if your temp. gauge never moves that's your problem. Your thermostat needs replacing. In the cold, the warmed up coolant really needs to flow past the thermostat which opens at a certain temperature....with a bad thermostat, this is not happening. Your temp. gauge in your instrument panel should be reading right at 3:00 when the car warms up and not move one bit from that spot.
To drive it hard, I'm talking about 60-80 MPH on the open road or interstate for several minutes. These cars need that at least once a week.
Klausc
- Year and Model: 1995 855 Turbo
- Has thanked: 5 times
- Been thanked: 15 times
It's a little colder here, so I put my select button on 'S' and shift to L once the car is moving down the road. That keeps it in 2nd gear until you come to a full stop (car will then shift to 1st). You will be surprised to know that you can get arrested in most states for redlining it in 2nd gear, these cars are fast!Red Brick wrote:Thanks, I'll head to a Volvo service department for a dipstick.
The oil cooler in the radiator is the problem, it keeps the oil too cold. Seldom will the oil get over 212F to cook the condensated water out, and in your wet climate???
Besides, running in 2nd is fun.
Klaus
Klaus
greasefingerss
- Year and Model: 850 wagon 1994
Moisture or water is a by product of combustion. On every engine (even a new one) there is always a small amount of blow-by!! What will blow-by gases have in it
Current Vehicles
1994 Volvo wagon(855) na 161,000 miles with AT
2003 Toyota Camry
1994 Jeep GC 202,000 miles
2003 Toy 4Runner
2003 Toyota Camry
2003 Toy 4Runner
I just might try to clean it. Thanks.
On my temp, I didn't mean to say the guage never moves, it just never moves after it warms up. Maybe I need to hit that gas pedal a little harder every once in a while.
1998 Volvo V70 GLT
1951 Willys CJ3A
2001 Lund Pro Sport
1951 Willys CJ3A
2001 Lund Pro Sport
redbrick
- Year and Model: 2005 V50 T5 AWD
Let's see........would it be better to do say 90-110 MPH or so every other week?MadeInJapan wrote:
Drive it hard, I'm talking about 60-80 MPH on the open road or interstate for several minutes. These cars need that at least once a week.
94 - 940
97 - 850 T5
99 - V70 GLT
05 - V50 AWD T5
97 - 850 T5
99 - V70 GLT
05 - V50 AWD T5
I'm trying not to tell you to do something illegal, but yeah....suppose that would work too.
- 5952 Views
Last post by Clemens
- 1091 Views
Last post by PS78
- 1598 Views
Last post by fontoledo
- 1088 Views
Last post by RAS69
- 22 Replies
- 4648 Views
Last post by newbieofthenorth2+
