ball joint 1990 740
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
jonesg
Year and Model: 2004 V70
Has thanked: 70 times
Been thanked: 483 times
ball joint 1990 740
Post by jonesg »
!990 740 wagon, the driver side ball joint doesn't want to let go, I did the other side a while back and a pickle fork n'ammer got it out after a few whacks. This one doesn't want to cooperate with my 3 lb hammer.
I'll buy a ball joint seperator tonite and have another go Friday and saturday, but on the offchance that the seperator doesn't work I know the whole assembly needs to come off, I plan on installing new cone bushings and sway bar links anyway.
My question is this, one of the bolts holding one of the links , is it the radius rod?, has a strange looking socket, its a star shape, male end, so I need a star female socket ...but what size?
I'll buy a set but want to be certain its IN the set.
I think this balljoint has 200K miles on it.
Anyone familiar with this?
Thanks.!
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Unfortunate that the usual big hammer technique has failed this time.
I have never seen just one 'odd' bolt on the steering/suspension. Is the other side the same? It is possible that someone has had this apart before and put a stranger in for some reason.
My friendly Volvo people have not come across this either.
Sorry, it is of no help.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
jonesg
Post by jonesg »
Bill if you're in England you probably wouldn't see one, I suspect its on the Regina only.
If the car were up on a lift I could get a better swing at it.
I'm from Manchester but live in Boston USA.
