88 Volvo 765 tic Ignition Timing
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
lummert
Year and Model: 760 1988
Been thanked: 26 times
Post by lummert »
Today I tried to check the ignition timing. Every time I advanced it the timing mark advanced by it self too far. When I retarded the timing it retarded too far on its own. Is this normal or do I have a harmonic balancer that is slipping? I ended up with the timing set in the middle of the adjustment range.
Thanks in advance for any input on this.
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
My book on the ignition system fitted to the 760 turbo has this:
Ignition timing is preset and programmed in the ECU (Electronic Control Unit) and cannot be adjusted.
It will, therefore always go back to the proper setting.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
lummert
Post by lummert »
Thanks billofdurham. I thought maybe that was what was happening.
sseir39
Post by sseir39 »
Bill is right. You can have a harmonic balancer that is slipping, but will not change the timing, just the perceived. If the rubber in the balancer is going out you might want to change it as they can be messy if and when they do go.
lummert
Post by lummert »
I am not sure if the harmonic balancer is going bad. It did not keep advancing, it just kept correcting the timing when ever I moved the distributor.
Thanks for your input
lummert
Post by lummert »
I stand corrected on the Harmonic Balancer slipping. I went out today with some the wife's bright nail polish and made a mark from the center hub to the outer pulley then started it up. Then shut it down. the marks were off.
Thanks for the input. Are Dorman Harmonic balancers any good?
sseir39
Post by sseir39 »
Not sure. I used an aftermarket unit with no problem. I was price shopping. Suppose it depends if you are into serious racing.
lummert
Post by lummert »
I looked up a harmonic balancer at FPC Groton and the have one from Scan Tech or MTC for $65.00
I found two at AutoPartsGiant.com
IMC $57.15
Dorman $73.64
lummert
Post by lummert »
Today I was checking on those harmonic balancers at AutoPartsGiant.com.
MTC Crankshaft Pulley $57.15 made in India.
Dorman Harmonic Balancer $73.64
Shipping is free on all orders $50 or more.
I think I will be going with the Dorman.
