Fuel Filter s80 2000
wilsontorres
- Year and Model:
Hi i changed the fuel filter but i'm not remember witch lines conection its the in and out ,i saw in the filter the oun and in conection but not in the gas lines,thanks
- Has thanked: 17 times
- Been thanked: 35 times
Maybe this will help in figuring out which way the rounded end goes into the bracket. By knowing the bracket position, you ought to be able to figure it out.
wilsontorres
- Year and Model:
Thanks so much ,for your help and faster responses. Sergio
wilsontorres wrote:Hi i changed the fuel filter but i'm not remember witch lines conection its the in and out ,i saw in the filter the oun and in conection but not in the gas lines,thanks
Most all fuel filters I've seen have an arrow pointing to the direction of gas flow, so all the guess work is out.....
2002, S80, T6
Turned 100,000 miles, May 2008..
I don't know what happened to my diagram I posted but you are correct...an arrow. I had forgotten. And of course, it runs from the back of the car to the front!
