1998 V70 WINDOWS AND SEAT WARMER QUIT
CALEBANDMICHELLE
Post by CALEBANDMICHELLE »
all of a sudden my drivers side and rear passenger windows will no longer roll down. i have no idea why. also, the drivers side heated seat button does not light up when pressed and also does not heat the seat anymore. any ideas? thanks in advance...caleb
Maxbaby
Post by Maxbaby »
Have you checked the appropriate fuses? With respect to the heated seat, pop the switch out of the console by prying gently with a small flatblade screwdriver. Then you can unplug it and test for power coming into the switch as well as continuity when the switch is turned on. If all is good there, check for continuity at the plug for the heater pad (plug at the front lower edge of the seat). If no continuity, then there's a break somewhere in the coil within the heater pad... that means replacing the pad itself.
1993 850 GLT
Close to 360,000 km
