hi matt,when replacing the head what should you torque it to.
your thoughts thanks
1990 .240 4cly automatic
craig Turner
- Year and Model:
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
First apply a light coat of oil to the bolts before inserting them. They tighten in three stages:
Stage 1. 14 ft.lbs (19nm)
Stage 2. 43 ft.lbs (58nm)
Stage 3. Additional 90 degrees.
For stage 3 it is easy to make an angle gauge using a piece of scrap wood.
Ensure you tighten them in the correct sequence.
Start at the centre two bolts.
The next two towards the front of the engine.
Go to the two on the other side of the centre.
Two at the front of the engine.
Two at the rear of the engine.
Bill.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
craig Turner
- Year and Model:
what do you suggest the final torque should be in foot /pounds... thanks
billofdurham wrote:First apply a light coat of oil to the bolts before inserting them. They tighten in three stages:
Bill.
- billofdurham
The final torque is not given as a ft/lbs measurement. It is the stage 2 torque plus the additional 90 degrees. That is why you need the angle gauge to get the 90 degrees correct.
Bill.
Bill.
Previously:
Previously:
craig Turner
- Year and Model:
thanks billbillofdurham wrote:The final torque is not given as a ft/lbs measurement. It is the stage 2 torque plus the additional 90 degrees. That is why you need the angle gauge to get the 90 degrees correct.
Bill.
