Transmission questions
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
537playing
Year and Model: 2005 S60
Has thanked: 1 time
Been thanked: 5 times
Post by 537playing »
90K miles. Transmission fluid changed @ 60k miles.
When driving on long road trips, I've notice a whinning sound upon overdrive and up hill climbs. At first, I thought the whine was from my power steering pump. Not the case as that reservoir is full.
When checking the transmission fluid when hot in Park position, it is over the mark with some bubbles. This can't be good, so am I checking the fluid properly?
Should I just get the fluid changed? Do I have a solenoid issue?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
You don say which model S80, but it does sound like it's over-filled. Did someone work on your car recently and add fluid? You know that on your car (if it's an automatic 5 speed) it takes a very special fluid. If someone added the wrong fluid this could be the cause. I would certainly flush and fill it again at your miles...once you start, you should be on a 30-35K mile flush and fill schedule anyway.
Good luck and let us know what you do and how your transmission is.
