Reco - Independent Volvo mechanic Chicago NorthWest 'burbs
aj98s70
Post by aj98s70 »
Hi All,
Could somebody recommend an independent shop/mechanic for my newly acquired 98 s70 with 72k miles.
Love the car !! But the Check Engine Light came on last week.
Any location close to the Arlington Heights, Mount Prospect area would be ideal.
Thanks in Advance.
regards....
1998 S70 GLT ~72k
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
Does the car run normally or is there anything that is out of the ordinary?
I can't help with a local mechanic but...
AutoZone and a few other parts houses will pull codes for free. If you have Emissions check stations that pull OBDII codes as part of the inspection they will typically pull and reset codes for a nominal fee - here in Atlanta the going rate is $10-20.
Order item 46030-1VGA UNIVERSAL CODE READER from www.harborfreight.com for $39 (picked this info from OZBrick - I would rather pull my own codes without relying on enybody else). It will read codes by flashing a LED and reset the code after it has been displayed 4 times. It will not reset the service light. Or get a more advanced model by clicking on one of Matthew's ads just below the banner.
Good Luck,
Tsquare
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
aj98s70
Post by aj98s70 »
Tsquared,
Thanks for the quick reply.
i will take your advice and take it to an AutoZone and have the codes read. The Volvo dealership wants to charge $50 for the service.
The car shows no perceptible signs of any problems - the engine runs smooth and the car drives good. I also checked to make sure the gas cap was screwed on tight. The person I bought it from said he changed the o2 sensors recently - apparently a common problem in the s70s. I just ordered a new set of OEM plugs that I am going to install in the next few days.
On a related note, is there a DIY publication for changing spark plugs ?
Thanks again for the info.
1998 S70 GLT ~72k
Tsquared
Has thanked: 1 time
Post by Tsquared »
I can't find a how-to on a spark plug change. It is a fairly strait forward procedure on the 96 850 and shouldn't be much different. Remove the torx screws on the top cover, remove spark plug boot, remove plug, take new plug with a dab of anti-sieze on the threads and install. Perform for all 5 plugs and replace top cover. Sorry I don't have tourque values...
You can go to www.amazon.com and perform a search on "volvo s70". The search will show "Volvo S70, C70 and V70 Service and Repair Manual: 1996-1999 (P to V) (Haynes Service and Repair Manuals)" for about $30. It is a good resource for many of the how-to procedures and the recomended service schedules.
Cheers,
'11 C30 T5
Stormin Norman
Post by Stormin Norman »
Swedish Engineering or sumthin like that in Schaumburg. He is an IPD dealer and repair shop. The IPD website can give you the exact name and address. Very nice to do business with, honest and smart.
j-dawg
Year and Model: 1999 V70 T5
Been thanked: 33 times
Post by j-dawg »
hey AJ, if you need one of top private Volvo mechanic in Chicago area, turboxc90 have contact for you he is very good volvo mechanic there is his email contact what you need direct.
castconcrete
Year and Model: 1996
Post by castconcrete »
Randy or Lester at Swedish Car Specialists in Schaumburg.
eight47 eight91 3133.
