shift button sticks on my automatic
i have an automatic 99 s70, the button on the shift nob stuck today while i put it in park from drive. i had to jiggle it to get it to pop out. my brothers 98 s70 has the problem everytime, while my has only done it once. it wouldnt be a problem except you cant take the key out while it the button is stuck in. has anyone else had this problem, any fixes?
1999 s70 AWD LPT
JRL
- Year and Model: Several
- Been thanked: 16 times
You need a new/used knob.
In the meantime, CAREFULLY shoot a little WD-40 inside the button area, that will help for a while
elcs70 wrote:i have an automatic 99 s70, the button on the shift nob stuck today while i put it in park from drive.
Hi there, I was looking around and found this in the repair database:
https://www.matthewsvolvosite.com/chat/p ... hp?p=31434
Hope this works for you.
- Has thanked: 17 times
- Been thanked: 35 times
Hey, thanks for your input but the shift release button and the shift knob are two different things. I replaced mine on my S70 as it was sticking and on further inspection, I found the plastic parts around the spring on the release handle was breaking out. Anyway, the wood grained one I replaced it with over a year ago is starting to do the same thing. I guess use some WD-40 or better yet, a silicone spray and try to to be gently getting it out of Park or putting it back in Park. Hate to have to replace these every few years.
- 810 Views
Last post by FMradio
- 1270 Views
Last post by oizdaman26
- 1198 Views
Last post by Vova585
- 503 Views
- 1338 Views
Last post by anothersullivan
