sub frame 0 rings 2000 S80
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
This topic is in the MVS Volvo Repair Database » Bulb Replacement Guide: Seven-, Eight- & Nine-Digit Volvo Bulbs
lowufo
Post by lowufo »
Does anyone know of a sub frame 0 ring # (size) from like napa / pep boys etc. that would match the ones required for the subframe bushings on an s 80 and probably other volvos.Normally this type of of item is available cheaper from local suppliers. hate to have to get smoked at the dealer
77700
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
try www.fcpgroton.com and eeuroparts.com too. Euro is cheaper maybe when considering free shipping for orders of $39 or more.
MIJ 8)
cudavid
Post by cudavid »
Hi, I ask that as I am chaceing a mystery front end clunking my 128K 2000 s80. Its had struts, spring seats, all tie rods, all disc/ brakes, all sway bar links, and I SILL have a clunk over bumps! even when light brak e pressue is appied, (I thought bad caliper bushings, and assumed this woud change tone / make clunk do away if it was the case. It had no effect) Thanks to all for suggestions, Dave
ohmfab
Post by ohmfab »
Mysterious clunking noises in the front end are usually either the spring seats, swaybar endlinks or the subframe bushings.
Clunking by the rear subframe bushings is fixed by the o-rings mentioned.
I did a write up a while back on replacing them:
https://www.matthewsvolvosite.com/chat/p ... 1628#31628
Good news is that they are only $22 from the Dealer for both of them and they come with new bolts. I doubt they can be found cheaper elsewhere.
