POSITION LIGHT BULB,S60 T5 2.4 ,AUTO 2001 UK MODEL 93000 MIL
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
asadjatala
Post by asadjatala »
S60 T5 2.4 ,AUTO 2001 UK MODEL 93000 MILES
Massage is displaying in dashboard: position light bulb failed and I have checked all the light bulbs and all seem to working fine .is there any body can help what cold be wrong. And what is position light may be its different what known about position light thanks
THANKS
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Position lights are usually front and rear sidelights and any other lights that may be on the sides of the vehicle which come on when you switch on the sidelights.
However, I have heard of some owners who have found that one of the number plate bulbs was out and the message was displayed.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Apparently it means that one of the position or "parking" lights is burned out. It is usually one of the four bulbs in the rear tail light assembly. Sometimes just slamming the trunk lid or tapping the light with your finger will fix the problem.
Here's how to change them:
Replacing bulbs in the tail light cluster
All bulbs in the tail light cluster can be replaced from inside the trunk.
Switch off all lights and turn ignition key to position 0.
Unlock and fold down the side panel to access the bulbs. The bulbs are located in two separate bulb holders, an upper and a lower. Each bulb holder has a locking pin. Replace bulbs in the upper and lower bulb holders as follows:
To ease the work: disconnect the cable from the bulb holder.
Press the catches together and pull out the holder.
Replace the bulb.
Reconnect the cable.
Close and secure the side panel.
Location of bulbs
1. Brake light - 21 W BA 15 s
2. Parking light (left side) - 5 W BA 15 s
3. Fog light (one side) - 21 W BA 5 s
4. Side marker lamp - 10W
5. Turn signal - PY 21 W
6. Back up light - 21 W BA 15 s
asadjatala
thank yoy very much both of you .it was rear side light
THANKS
