B230F (non-turbo) engine temperature
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
e777
Year and Model: 1990 740
Has thanked: 11 times
Post by e777 »
I have a 1990 740 GL wagon with 265k miles. Since I've had the car (the last 5k miles) I've noticed that the temp gauge needle, when the engine is running, is pretty much pegged straight up. This means that the needle is much closer to the red zone than the cool zone. It seems that if I were to drive the car in very hot temperatures, then there wouldn't be a whole lot of room for the engine to heat up before hitting the danger zone.
In short, is it normal for the needle to be vertical in normal operating temps (60-80 degrees)?
Thanks,
Eric
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The normal running position of the temp gauge needle is about half way between cold and hot.
What colour is the coolant? If it has a rusty tinge then it is possible that your cooling system needs to be flushed - back flushing of the radiator is the most effective way.
If the coolant is the normal colour then the thermostat is probably sticking partially closed and slowing down the circulation of the coolant.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
