Hi folks:
Just yesterday our 940 with 168k started exhibiting erratic behavior. Our RPMs will drop to 0 and we will get no response from the engine for a few seconds and then it will jump back. About 10% of the time the engine won't come back and we will glide to a stop. It seems to happen at all speeds and starts up after we have been driving for about 20 minutes. This is not good and we are very nervous about taking it into a dealership and getting soaked. Would love some feedback and any suggestions. Thanks!
1993 940 RPM drops and stalling
- billofdurham
- Year and Model: 855, 1995
- Been thanked: 5 times
Have you checked for any fault codes that may have been set as this happened?
Your vehicle is fitted with an On-Board Diagnostic unit (OBD) in the engine compartment. Using this you can see if any codes are there.
To use it see:
https://www.matthewsvolvosite.com/chat/p ... c&start=12
The instructions do cover your car.
Check this first and let us know if fault codes are there. If not, we go back to basics.
Bill.
To use it see:
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Previously:
Thanks for the reply. Do you have a diagram for the 940 that shows exactly where this onboard diagnostic tool is? I was looking under the hood without success today. Unfortunately, I am pretty inexperienced with this type of thing.
Thanks.
Thanks.
- billofdurham
It is behind the left strut tower and looks like this:
It should have a cover on it but sometimes they go missing.
Bill.
Bill.
Previously:
Previously:
Thanks for the self-diagnosis info you've given here, billofdurham.
My '91 940 has hot stalling problem
The diagnosis code given was 2-3-2. The sheet says lambda adjustment: check intake manifold, check fuel pressure.
Where shall I start?
The plugs, fuel & air filters were replaced couple of weeks ago.
Thanks
Thanks
- billofdurham
To test the intake manifold start the engine and spray a small amount of water or WD40 along the gasket between the manifold and the head. If the engine starts to die there is a leak.
To test the fuel pressure you need a fuel pressure gauge to do it accurately. It is something that any self respecting small shop owner would do for you - not a Volvo main dealer - or you could buy the gauge and DIY. Probably cheaper to have it done as it is not something you should be doing every week.
Bill.
Bill.
Previously:
Previously:
I finally figured out where the diagnostic box was. Here is what I did.
I plugged it into slot 2 and it returned "111".
I plugged it into slot 6 and it returned "144."
Should I plug it into any other slots? Thoughts on the "144"?
Thanks!
Thanks!
- billofdurham
1-1-1 means no fault codes have been stored.
Socket 6 tests the ignition system. Code 1-4-4 is "Fuel System Load Signal".
Go back to the link for the on-board diagnostics, scroll down to pages 7 & 8 to find out how to check this.
There are no other sockets used on your car.
Bill.
Bill.
Previously:
Previously:
