I just tried to post a .pdf and it came back as not an allowed extension. It did work in the beta site after you adjusted it.
More grist for your mill?
I feel your pain.
PDF files
- Year and Model: Many Volvos
- Been thanked: 76 times
PDF files
- Has thanked: 17 times
- Been thanked: 35 times
You are right...I just tried and it wouldn't let me either.
- Has thanked: 2664 times
- Been thanked: 1256 times
Fixed.
512 KB limit... this should be enough, but I'll up it if necessary.
Matt,
I can see why that's the problem to begin with but I'm thinking it's still going to be an issue. Many of the PDF's that I've culled out of VADIS are 1MB or a bit more.
^^^ I upped it to 3MB. No use coming this far then chintzing out on an upload limit.
Thank you...it will be few and far between when I would need that much but seems with these pdf's a lot of pictures are embedded which ups the size.
MIJ,
One other thing I noticed (at least with IE-7) is that all of the sigs wound up with an extra space in them between the lines. I edited mine and it looks OK now on IE but I don't know how it looks on other browsers.
You guys may all look fine on Foxfire and I look like crap with no line feeds but on IE-7 most of the converted member's sigs are all double spaced.
Mine has spaces too...thanks for the hint. I'll go edit mine now!
