2002, v70
my gas lid button stopped working, so i disconected the ground off the battery. 30 seconds later i reconnected the ground wire. now my sunroof, interior lights, keyfobs and visor mirror lights dont work. what did i do wrong and how can i fix it
I need help
Free Endlinks When You Buy Control Arm Pair at IPD
- Has thanked: 17 times
- Been thanked: 35 times
Welcome to MVS. When you reconnect the battery with your particular model, you're suppose to have the ignition key in position II (almost to III where the car starts, but not quite). Disconnect the battery again and put your key in this position before reconnecting and see if it makes a difference. If not, then check your fuses.
They are a pain in the butt because even if you find a new one it will have to be "married" to the car with software at the dealer. This little mirror has much more in it than just a chip- it is the brains for your security system for your car among other things. There is a thread here on MVS that shows you potentially how to repair your own. This should get you started: https://www.matthewsvolvosite.com/forums ... hp?t=16275
