2001 s40 trouble codes
1996 - 2004 S40
1996 - 2004 V40
geeman
Post by geeman »
i have a 2001 s40 with trouble codes po133 and po128 what do i need to do
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
It is possible that the codes are linked.
P0128 is a faulty engine thermostat. Replace it.
P0133 is the front heated oxygen sensor which sends information to the ECU about the fuel/air mixture. As the thermostat is faulty the information will inaccurate. This fault may rectify itself when you replace the thermostat.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
billofdurham
I have received the following in a pm from geeman. I am adding this to the topic as it is of general interest.
I was getting two codes. I changed my thermostat as suggested that code is cleared. I was still getting po133. I changed my o2 sensor but I am still getting code po133 and now also po107. what do I need to do next
P0133 is a slow response from the O2 sensor which may be a fault in the wiring. Have you checked the wiring is properly connected?
P0107 is the Manifold Absolute Pressure (MAP) sensor/Barometric Pressure (BARO) sensor low input. The probable cause is a wiring short to earth (ground) at the sensor or the ECM.
Bill.
Previously:
