Repair database
Maxbaby
Repair database
Post by Maxbaby »
Not sure who to send this to, so I'm posting here... I just tried to click the links for MAF sensor and MAF problems in the database but they seem to be broken... was I clumsy and break something again?? :oops:
1993 850 GLT
Close to 360,000 km
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
So it was you!!
I've passed it on to Matt.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
Hmmm yep, I think we lost that link in the big conversion last month.
If you can find the MAF thread, or just a good MAF thread here https://www.matthewsvolvosite.com/search ... Search#957 let me know which and I'll fix that Repair Database link with it.
Also -> Amazon link
Maxbaby
Post by Maxbaby »
Matt I spent some time trying to find the post but can't. I also found that the link to the Oil sump o-ring replacement is missing. I searched for quite awhile but can't seem to find how to locate old posts. I also posted this particular problem in ...
https://www.matthewsvolvosite.com/forums ... 8&start=10
...at the bottom. As you can see I can pull up the original introduction to the repair procedure, but for whatever reason, it won't bring up the original post. :cry: I tried.
1993 850 GLT
Close to 360,000 km
Maxbaby
Post by Maxbaby »
And here's another post where it seems what I pasted in has been lost...
https://www.matthewsvolvosite.com/forums ... &sk=t&sd=a
I had posted the technical bulletins to this thread and now they seem to have been lost.
Matt, do you want me to re-post them to that specific thread or should it be a brand new one?
1993 850 GLT
Close to 360,000 km
matthew1
Site Admin
Post by matthew1 »
Max, can you PM me the content of those and I'll fix that post?
Also -> Amazon link
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
Everything that I click in the repair database directs me to the forums menu. I was looking for a specific post that was in the repair database and couldn't link to it. I used the search engine and found it so everything is still there - it is just not linking correctly.
Maxbaby
Post by Maxbaby »
matthew1 wrote:Max, can you PM me the content of those and I'll fix that post?
When you say PM you the post... do you mean send you the three saved documents?... I'm not as literate computerally as I am about other things... Or do you mean for me to cut and past them into a message to you?
1993 850 GLT
Close to 360,000 km
matthew1
Site Admin
Post by matthew1 »
Ozark Lee: fixed. I made a change a day ago that caused that. :oops:
Max: PM = Private Message, but why don't you just attach them to a post in this thread, and I'll get/fix them.
Also -> Amazon link
Maxbaby
Post by Maxbaby »
Sea Foam Amounts in Fuel
4 Cycle Type Engines
Diesel
Rotary (Wankel)
2 Cycle type Engines
Sea Foam Products recommends an average of 1 ounce Sea Foam Motor Treatment to each gallon of Gasoline (including 5%, 10%, 12% & 15% Ethanol) and Diesel fuel, including (off road low sulfur) & Ultra Low Sulfur blends.
With any vehicle or system using E-85 fuel, use 2 ounces Sea foam per gallon of the fuel.
For Ultra Low Sulfur Diesel blends, Sea Foam recommends a MINIMUM of 1 ounce Sea Foam Motor Treatment per gallon of the Ultra Low Sulfur Diesel fuel. Using more Sea Foam adds more Lubricity.
Parameters are: 1 – 16 ounce can of Sea Foam Motor Treatment to a MINIMUM of 8 gallons of fuel, Maximum 25 gallons fuel to a 16 ounce can for maintenance. Follow the instructions above for OIL INJECTED engines also. (NO Sea Foam Motor Treatment ever goes into the oil reserve tank for oil injection engines!).
***For all gas/oil mixed fuels (2 cycle) use 2 ounces Sea Foam per gallon of the mix. If your fuel is E-85, use 3 ounces per gallon of the E-85 and oil mix.
Sea Foam Motor Treatment is blended OIL, and will not run a gasoline, Gas/oil mix or Ethanol engine without introducing HYDROCARBONS (gasoline or gas/ethanol blend) .
Fuel injector cleaning machines in a controlled environment use Sea Foam Motor Treatment as their safe Cleaning agent mixed with gasoline or ethanol blend at a ratio of 50 to 60% Gasoline/Ethanol blend PLUS 40 to 50% Sea Foam Motor Treatment.
Technical Services Department
Sea Foam Sales Company
Minneapolis, Minnesota
Updated July, 2008 DD
1993 850 GLT
Close to 360,000 km
