Transmission Advice
DCintraining
Transmission Advice
Post by DCintraining »
I've looked at all the transmission related posts, but I need some more advice.
I have a early 1993 850 GLT nonturbo with 185K miles. My wife and I received this vehicle as a gift from my in-laws when we moved back to the east coast 2 years ago (162K).
First, I'm in Grad school and would like to keep this car until I graduate in $125K err 3 years. Lately the trasmission has been feeling a little "clunky" and makes at little "swishing" briefly (approx 1 sec) when first accelerating past 15 mph after starting the engine. My father-in-law doesn't remember when the trany was flushed, but a little sticker on the airbox indicates that it was done 138K.
I could flush the system myself (using advice from the forum) but I have several concerns.
1. How much transmission fluid would I reasonable need to buy to flush the system?
2. What type of fluid should I buy?
3. Being environmentally friendly, where should I bring the old stuff for proper disposal?
4. Would I be better off having it serviced by a transmission shop or a independent garage?
Thanks for all the advice and help!
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
I used 12 quarts in my inefficient method. The system takes 8 quarts. I'd recommend the tube method, where you affix aquarium tubing to a nozzle and the car pumps it out while you add in fluid via the dipstick.
There's this and two or three more tips here https://www.matthewsvolvosite.com/tips_content.php (search on 'ATF') that document this method:
LAgte
11/18/2001
Piece of cake to flush yourself. Remove exit hose from tranny to radiator at the radiator attachment point. A snap-ring pliar is highly recommended to remove clamp. It looks like you can do it with a screw driver, but clamp damage is highly probable, and you don't want it blowing off later in traffic.
Run engine until bubbles show up (clear hose is nice--and 850, S70, V70's are kind to the mechanic because the drain is on the driver's side, allowing one to watch the progress out the driver's window), shud down, add a couple quarts of tranny fluid, then keep repeating until you are satisfied it is clean--I think I pumped 9 quarts through my wife's 96 turbo wagon with 85K and wished I had had about three more quarts to get it crystal clear. Top it off and put the hose back on. I used Castrol synthetic blend mostly because I could not find pure synthetic locally. And I think I would rather go with more frequent changes at a lower cost rather than extended service with synthetic.
Dextron IIE/III
Call auto parts stores in your area. Most around here take fluids for free. Buy an oil drain pan for easy used fluid transport.
It's a time/money tradeoff, as are most do-it-yourself things :-). A bonus to doing it yourself is that you gain an understanding of how things work that may be useful one day in an emergency.
Also -> Amazon link
