99 S70 turbo, Where is the throttle body? I was told that the reason for my engine to pulsates at idol rpm's, is due to my need to clean the throttle and the banjo bolt. I have no idea where they are or how to do it? When the car was under warranty the service dept did it. Now, i am unemployed and forced to do it myself.
CAN ANYONE HELP ME???
Throttle body / banjo bolt Topic is solved
find your air box, then follow the intake tube to the engine... Where the plastic tube clamps onto a metal block, that's your throttle body. You should see your throttle cable go to the same location. Remove the plastic tube and clean both the inside of the tube, and the throttle body with carb cleaner. Simple Green works, as well.
