I have a 95 850 T and just lost the transmission. I am getting a used transmission put in next week. I assume that the engine will probably have to be dropped for this repair. Is there anything else that I should look into having done while the trans is getting replaced?
Thanks in advance
Transmission Repair
1998 V70 GLT 19T Build
meteg
- Year and Model: 2007 V70 2.0T
Hello,
do not forget to have the engine rear main seal changed if you havent..before the trans is installed back in the car. and inspect the engine mounts when the engine is removed.. if they look bad have them replaced.
- 1613 Views
Last post by CIK7
- 1324 Views
Last post by alschnertz
- 1704 Views
Last post by rasense
- 2238 Views
Last post by tryingbe
- 3024 Views
Last post by mayfair
