My 1991 240 DH turns over but will not start. We had a terrible rain storm the other day
so I took off the distributor cap and made sure no moisture was present,
even took fingernail file and made sure the contact points were fresh. Can
you tell me how to check and see if I'm getting spark? Do I start at the
solenoid and work my way down? Also as per the codes from A2 to A6, is there
a way I can find out what all of the codes mean? thanx for any help.
Coby from Brooklyn
volvo 240 won't start Topic is solved
Guest
Check your fuse box look for the Main fuel pump fuse turn it an make sure It is making a good contact. Crank you engine one revolution stop and listen you will hear the fuel pump
Guest
Guest
- 6288 Views
Last post by volvolugnut
- 13 Replies
- 1168 Views
Last post by 122sPhil
