code P1618, P0751 on '01 S80 T6
Everything on the Volvo S80. Sometimes called an "executive car", the S80 was Volvo's top-of-the-line passenger car. P2 platform.
jborgwardt
Post by jborgwardt »
My transmission is acting up so I checked to see what codes came up and found two, P1618 and P0751. I cannot find out what the P1618 is and can it be fixed without having to put in a new transmission?
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Codes are typical of a speed sensor malfunction too which can mimic transmission codes. Check to make sure it isn't the problem.
VCA
Been thanked: 5 times
Post by VCA »
jborgwardt wrote:My transmission is acting up so I checked to see what codes came up and found two, P1618 and P0751. I cannot find out what the P1618 is and can it be fixed without having to put in a new transmission?
MIJ is correct, ABS and Vehicle speed sensor issues can mimic transmission problems in P2 cars. For your knowledge, P1618 is simply the "transmission MIL request" P-code. It means that the ECM (which controls the check engine light or "Malfunction Indicator Lamp" [MIL]) was asked by the transmission control module to turn on the MIL because the TCM has faults logged.
2008 S80 T6 AWD
1999 S70 GLT
