Programming the sun visor garage door opener
warrenjoel
- Year and Model:
I replaced my 99 V70 XC driver side sun visor with one that has a programmable 3 button door opener. How, if possible, do I clone the code from my hand held garage door opener. Thank, Joel
VCA
- Year and Model: 2008 S80 T6 AWD
- Been thanked: 5 times
Instructions depend on your opener. You'll be registering it with the opener, not cloning the code, so you might need a ladder to push the 'learn' button on the opener. See: http://www.homelink.com/home/home.tafwarrenjoel wrote:I replaced my 99 V70 XC driver side sun visor with one that has a programmable 3 button door opener. How, if possible, do I clone the code from my hand held garage door opener. Thank, Joel
2008 S80 T6 AWD
1999 S70 GLT
1999 S70 GLT
warrenjoel
- Year and Model:
Thanks for info!
Can I instruct the a condo gate to register with my home link visor? I cannot seem to get the buttons to flash. Pressed two outside buttons while ignition at "on" position. Nothing...defective? Or am I the defective link?:) Thanks again, Joel.
JRL
- Year and Model: Several
- Been thanked: 16 times
If you have a "rolling code" it's a bit more difficult and the garage motor has to be programmed.warrenjoel wrote:Thanks for info!
If you do not, you program it to the remote
If you've pushed both outside buttons and held them for 20 seconds, they should flash, if not, the homelink is broke!
warrenjoel
- Year and Model:
I think it's DOA. Thanks for the heads up....Joel
