The belt that connects the compressor to the crank pulley is missing. However, looking at the belt diagram, there is a tensioner or idler pulley that it runs around that is rusted frozen. I'm guessing the first step would be to get a belt on there with a new tensioner, now what is this tensioner called and can I get it from FCP or ipd? (It's just a pulley with a bolt running through it from what it looks like). When I was just testing, I activated the AC switch on the dash, whilst spinning the compressor by hand, but it seemed the clutch did not engage because the compressor still freely spins. I don't know if this is a valid test, but I'm just putting it out there. There's no sticker on the accumulator that says (134A) so I'm guessing it's still R12. So I don't know if it's more economical to convert to 134a -- also is there a quick way to test the electric fan in the front of the grille?
Any help would be appreciated before the warm weather
Also, someone mentioned that reconnecting the AC on an older car will suck the life out of the engine... it sounded a little farfetched to me, afterall it's only one more belt, but just wanted to see what you guys had to say about it.
Thanks!
