Difference between V70 and XC70 suspension
Zoll
Post by Zoll »
Hi, my 1998 V70 AWD rear end is very low (can't see the top of the tires) and every bump on the road feels like I'm hitting the bump stops. I looked under the car last night and could see some oil on the rear control arms, right under where the shocks are (Nivomats). So my diagnosis is blown Nivomats on the car. I looked on the internet for some used ones and find a set for 175.00$ each. They are coming from a 1998 XC70. I am worried that it won't fit my V70. I checked the product ID on both cars, 5th line, 4th digit is a "M" on both cars. Should these fit despite the suspension's height difference between the XC and V70?
Year and Model: Many Volvos
Been thanked: 76 times
Post by Ozark Lee »
VADIS shows both cars with the M code to be the same shock, part number 8626027.
Zoll
Post by Zoll »
Excellent news! Does anything else should be changed along with the shocks? Bushings etc...
holler1
Post by holler1 »
I'm surprised the used ones are that expensive, considering new ones on FCP Groton are $275 each. I hope those come with a warranty.
BTW, one of the forums (not sure which one, maybe Swedespeed or volvoxc, did a survey on what people who had Nivomats did when they wore out, and most apparently found a kit that enabled them to replace them with regular shocks. I believe additional springs are needed too, so it couldn't have been much cheaper. I have the "Ms" too but mine are still doing reasonably well, although a little soft.
1998 Volvo V70 AWD 165000-R muffler, HD endlinks, boost gauge
2008 Ford Fusion AWD 107000
2000 Ford Ranger 4wd 172000
1991 Toyota Camry 160000#1
Previous: 1982 Volvo DL (240) 160000
1998 Tacoma, Fords (6), Dodge, Montero,
GTO, Sunbeam Alpine, VW Dasher
Zoll
Post by Zoll »
New shocks, springs and mounts would probably be more expensive. The shocks have a 3 month warranty on them.
I looked at the rear of my car after a drive on the highway, it will raise the rear about 2 inches once I'm stopped. 40 minutes later, the wheel is back tucked in the fender. Ride is very rough. Hope it will fix it.
895meztz94
Post by 895meztz94 »
It will. It is higher after you drive because the Nivomats pump themselves up.
1999 Volvo V70 2.4 Base 207k miles and counting
2003 Saab 9-5 Linear
