I have a 2001 v70xc and the check engine light came on and it had began running rough. I checked here on this forum and it seemed like a good cleaning of the MAF sensor might help. I used the cleaner (CRC MAF cleaner) and reassembled every thing and the CEL & rough idle continued.
I came back to the forum and took the advice to a take the car to AutoZone to have the codes read. The codes were P1171 and P0303. P1171 is for the MAF sensor and P0303 is a misfire on the #3 cylander.
My Questions are:
1). Is the misfire due to the sensor since they both happened at the same time?
2). Should have the codes been reset after the cleaning? Would this eliminate the CEL & rough running?
3). Do I go for the new sensor then reset the code?
4). How do I reset the codes?
5). Is there more I should know?
Thanks for the help in advance.
Check Engine Light - I need advice. Topic is solved
Check Engine Light Set by Failing Coils
larrycrilley
- Year and Model: v70xc 2001
mijo850glt96
- Year and Model: 1996 850 GLT
1) not necessarily because the misfire could be traced to a bag spark plug gap or wire, which in the end can lead to an electrical problem with the distributor.
2)I would not say that just cleaning the MAF would clear the codes and engine light because many times its a preliminary step. The worse outcome is that the MAF is damaged and reading incorrectly, or the rough running could be a completely unrelated problem.
The way I see it is if you are having a spark problem with the 3rd cylinder try to find the problem and fix that. If the car is misfire it would respond with a loss of power and sometimes there will be black smoke coming out of the exhaust. If you can fix the misfire it would tell you if your MAF is truly broken.
SilverBullet
- Year and Model: V70 XC 1999
I had a Subaru that did the same thing.. read the code it was a misfire in cylinder 3.. ended up being i just need to replace the plugs.. like i said that was a Subaru and not a Volvo. As for the MAF like he said above.. you will know more when the misfire is gone, like if the MAF is damaged or something
larrycrilley
Thanks for all the advice and help' I swapped out the the coil ($75.00 dealer part) and my problems were solved. I cleaned the MAF sensor and it was no longer an issue. Went to my local Autozone and reset my light. All is well with my wonderful XC70!
z28chuck400hp
- Year and Model: 2001 xc
trying to solve a problem with my 2001 xc. I have found that if you disconnect the battery for 30 min. and turn the key on, then reconnect the battery, the check engine light turns off....it comes back on if the problem still exists...worth a try let me know if this works for you
- 6284 Views
Last post by Vova585
- 6363 Views
- 2786 Views
Last post by Georgeandkira
- 1437 Views
Last post by balabaika
- 2945 Views
Last post by JLGParis
