S40 2000 Shuddering problems
1996 - 2004 S40
1996 - 2004 V40
knightsar
Year and Model: S40 2000
Post by knightsar »
Hello all, I am new to the site and hope you can help me.
I have a 2000 S40 with automatic transmission and the 1.9T. It has 141,000 miles on it and ran great until this problem.
I recently have a shuddering when the car has been driven for about 10 miles. It started after I had sprayed the engine off at a car wash trying to be careful not to get the wrong things wet. Car has the check engine light on and it normally comes on in the winter and goes out when the weather gets warmer. It is staying on this time though. It kind of shudders and loses power driving from 60-75 mph. It only dose it when the car is at highway speeds and after the care has been driven at highway speeds for more than 10 mins. It is fine once I get off the highway and in traffic.
If I give it more throttle it just shakes violently until I lift off the throttle and it goes away. It only happens when the motor is under load. Seems the longer you drive the car it goes away.
I have changed the plugs with no help and also bought a new coil and switched from the 3-4 cylinder with no change. I have tried changing gas also with no help.
I have been hit bad with the economy and can not afford to take to a shop for repair so I need your help in a bad way. I need to be able repair myself if possible. :(
Would you think I should try another coil to eliminate that completely before moving on?
Remember it drives fine in the city stop and go and just dose it after being driven at highway speeds for at least 10mins or 10 miles.
Thanks In advance for any help.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
It is hard to diagnose from far away-
Have you had your trouble codes read?
Almost sounds like a transmission problem that could be alleviated with a transmission flush.
knightsar
Post by knightsar »
MadeInJapan wrote:Welcome to MVS.
No, it most certainly a engine related problem. The engine gets really loud when it starts doing it. You can feel it through the steering wheel and hole car.
I may get it into a shop soon to be able to get some codes out of it.
rogeraperkins
Post by rogeraperkins »
mine is doing this too. I have changed out both coils and a oxygen sen. Still does it. I am thinking it is my computer. The code on my indicated a bad oxygen sen still. Let me know what you find.
