Head Gasket Complete, starts, what's with the ticking?
WarWagon
- Year and Model: S60 2006
I am happy to report that with allot of help from this forum, I completed the removal/replacement of my head gasket to include a new head from Clearwater Cylinder Head. Car started all was well... I think.? Now keep in mind I haven't heard the car run since November 2008, but I don't remember the ticking/clicking, which sounds like the valves. It seems to be uniformed throughout the motor. Is there a "break in" period for this. I am pretty sure the folks at Clearwater told me they did all the valve adjustments and torques, so it was an unpack and install head. Could I be off a tooth on either the exhaust or intake pulley? I think I might take off the timing belt cover and check the allignment again. I know it's allot of questions but, any suggestions?
Mike
97' 850 GLT Wagon
06' S60
06' S40
97' 850 GLT Wagon
06' S60
06' S40
- Has thanked: 17 times
- Been thanked: 35 times
If it hasn't been run in awhile you might get some ticking at least at first- I assume you didn't touch the lower section (oil pan off?)...and oil pick-up lines are fine. You can take the oil filler cap off (idling) and see if oil is being pulled up to the top of the engine and spilled out over the cams. If all looks good then I would think that after a bit of running things will quieten down quite a bit. Of course it would be prudent to check your timing marks if you have any doubt but typically if you have a tooth off you would not have power and your car would exhibit much more than the ticking- some exhaust issues (smoke for instance) and some idling issues. Good luck and let us know how things go.
Btw, were you please with the service and the head you got from Clearwater?
mrreilly
- Year and Model: 1998 Volvo S70 GLT
I had the very same problem after my head gasket repair. It did go away, but I don't recall how long after the repair that is finally stopped. It doesn't hurt to check your alignments though and make sure everything looks good. I know I watched mine several times after I got it running.
1998 Volvo S70 GLT Black/Tan
Approx. 173,000 3/27/2010
My major repairs:
Timing Belt, Left&Right Control Arms, Tie-rod ends, Lower Engine Mount, Engine Stabilizer Mount, IPD Sway Bar Links, Brakes , Head Gasket, PCV System, Turbo Rebuild, and more
My major repairs:
WarWagon
My paranoia was just that. All is well and the ticking is gone. All my timing marks were still good and now the motor sounds great. This project was a true confidence builder and after all was said and done, only two screws were left, they were for the fan shroud which I replaced with different hardware. The shadetree mech in me is now looking for another project for the car. I washed and waxed it yesterday, so I guess I'll need to find something else that doesn't cause any more gray hair. Thanks to all but specifically Ozark Lee, MadeInJapan, bigric, bobsnow, S40_guy, mrreilly, and C@lvin. You guys made time under the hood less painful and an ultimate success. Also FCP Groton and Clearwater Cylinder Head are great places to do business. More good news, Clearwater will give military discount too, which made the project more affordable. See you guys on the highways. Semper Fidelis. Mike
Mike
97' 850 GLT Wagon
06' S60
06' S40
97' 850 GLT Wagon
06' S60
06' S40
