Rim change affects?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
reinier claasen
Year and Model: V70 t5 2001
Rim change affects?
Post by reinier claasen »
Hi, I'm brand new to the volvo experience. Never owned one or personally new any on e who did but am buying one now. My question to you is the following:
The var came out with 215 55 R16 rims and tyres. The previous owner went and put 245 45 R18 rims and tyres on. Is that going to affect the car any how and is it not putting heavy strain on the gearbox?
2001 Volvo V70 t5 - K&N Air filter
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Welcome to MVS.
tire and wheel size does make a difference in what kind of mileage is displayed on your odometer and speedometer, making them off if there is a big difference between recommended and what changed. That said, here is a calculator to use to look at different dimensions for the tires:
http://www.miata.net/garage/tirecalc.html
In your specific case, the 18 inch tires on those rims will cause you to be 5.4% slower than what you are really going, so you have to watch out on your speedometer when you fly by a cop...you can think you're under the speed limit when you're not... The other consideration is whether there is any rubbing on the fenders or not with the larger size tire. I would say that this much difference (not a lot) will probably be okay (others on this site however know more about this than I do)- there will not be much strain at all on the drivetrain, so that should not be a worry.
VCA
Been thanked: 5 times
Post by VCA »
MadeInJapan wrote:Welcome to MVS.
MIJ is correct...for the most part. In certain circumstances, the dimensions being off can affect operation of the ABS and traction control systems causing unwanted activation (i.e. ABS activates when it doesn't need to). If the speed being off, or the potential for ABS issues bothers you, have the dealer install software program "Circumference 2085 Application" (Volvo 30656219)
2008 S80 T6 AWD
1999 S70 GLT
reinier claasen
Thanks guys. You saved me from major speeding fines :twisted: :twisted: That progam that the dealers load up, is that just plug and play that they plug in on your car ecu or how does it work? I was more conserned about the drivetrain affect but it's good to know it won't.
VCA
Post by VCA »
reinier claasen wrote:Thanks guys. You saved me from major speeding fines :twisted: :twisted: That progam that the dealers load up, is that just plug and play that they plug in on your car ecu or how does it work? I was more conserned about the drivetrain affect but it's good to know it won't.
Volvo's weird about software...software downloads are "parts"...that one costs $25.00. It's a program that changes the settings in the Car Configuration File so that all the modules know what size tires are installed...then it updates Volvo's PIE server, so the system knows how the car is configured (that way, if in the future the car needs a reload, the system knows exactly what options are particular to that car).
2008 S80 T6 AWD
1999 S70 GLT
