960 1996 CEL
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Jessi
Year and Model: 1996 960
960 1996 CEL
Post by Jessi »
I just bought my first Volvo! I love the car...but within two hours of purchase the check engine light came on. My friend looked at it, checked the fuses etc..I got an oil change. The light went off and stayed off for two days. It's back on and I'm a bit worried. It seems to be running fine. What can I do to find out what the problem is? I don't want to get taken advantage of, I am a female..know a little about cars..but not too much about Volvos.
Any help is much appreciated! - jess
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
The Check Engine Light (CEL) indicates that a diagnostic trouble code (DTC) has been set. On the '96 model you need to have the DTCs read by a scan tool. Autozone and similar places will read the DTCs free of charge. Have the codes read, make a note of what they are and post back for help.
Don't let them persuade you to have a repair done by them until you find out from here what the codes mean and what is needed to sort things out.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
Jessi
Post by Jessi »
Will do and post info tomorrow. I am so glad that I stumbled across this site! I don't feel so alone in the world :lol: !
Jessi
Post by Jessi »
OK. I ran the computer test these are the codes:
P0304 - Cylinder 4 misfire detected
P0300 - Random / Mulitiple misfire detected.
As a note the car does not seem to be running bad, it is not shaking when I drive. I want to learn how to make the repairs on the car ,myself. I do have someone who can help me. Any information that you can give me is appreciated!
DeRail
Year and Model: None
Post by DeRail »
Jessi,
one of the best investments I've made with my Volvo so far was the purchasing the repair manual. Try to find the Haynes or Chilton's repair manual for your 960. Any of the local auto stores will have it and if they don't then they can order it for you.
As for the engine misfire issue, have you any idea of the last time the spark plugs were changed on the car?
Darrell
billofdurham
Volvo owners are never alone. We may not be able to answer everything but we give it a darned good try.
The codes are linked and probably both apply to the same cylinder #4 as my book says that P0300 is a misfire on at least one cylinder. A misfire could be a bad spark plug or the ignition coil which sits on top of the plug. One thing that may be a little more of a problem is that P0304 also points to possible damage to the three way catalytic converter. However, that doesn't necessarly mean there is damage as the computer can often read more into a situation than is there.
As you have just bought the car you probably don't know when the plugs were last changed, unless the previous owner has given you a service record. If you don't know then, for the cost of them, it may pay to change all six as a first step. When you have done that have the DTCs erased and see if they come back. Doing it this way keeps costs to a minimum as you aren't repairing something that may not be broken.
I hope this makes sense.
Keep us posted.
Bill.
Previously:
