I have an '04 S60 with a little over 120,000 miles on it. I'm getting a vibration from the front end along with a clunk over bumps. I've been told the lower control arm bushings need replacing. So I've decided to just replace most of the suspension bushings in the front end. I plan on purchasing the replacement lower control arms with the new bushings already included to avoid the hassle of pressing the bushings in. Plan on replacing the ball joints while I'm there also. Recently purchased the heavy duty spring seats from IPD so I'll throw those in along with some new sway bar links. Needless to say I hope this will cure my problems. I plan on doing this myself some weekend. Are there any special tools I will need other than the strut nut spanner tool and spring compressor? Is there anything else I should replace? Don't think it's quite time to replace the struts yet as the ride is fine and they don't show any sign of leaking.
Any tips, suggestions, or advice would be much appreciated.
Thanks ahead of time..
Front End Overhaul
I would check out your C/V shafts, they could still be fine but they are right there
If you do replace the C/V shafts then might look into replacing the seals
Axle Seaks
As far as special tools, Id recommend VADIS, I have read about replacing the front control arm and you have to drop the subframe or lift the engine to get to a few bolts
Axle Seaks
2002 S60 T5M
ive looked at replacing the control arm, should have done it when i pulled the drive shaft!!. in vadis it lists that you have to tie the two control arms together with a winch strap when its all loose, loosen the lower motor mount bolts and raise the engine 33 mm to access the arm mounting screws. it looks like there is enough room to clear on my frame, i think it varies by model .
2002 BMW X5 3.0
2001 v70XC 206K
2002 v70XC 173K
96 850T wagon 194K-sold,
2004 Cadillac SLS- sold
2004 Chevy Avalanche 42K
2001 v70XC 206K
2002 v70XC 173K
rbodor3
- Year and Model: 01 S60 LPT
- Been thanked: 2 times
you don't really need to do that for all vehicles. What I did was lift the front end, remove the ball joint nut, and then you can either ratchet-wrench the CA to get it loose from the strut or you can use a long rod to pull it down to give you leverage.
I could get to both bushing bolts & nuts with just some maneuvering.
01 Volvo S60 2.4T
Have any of you used meyle parts? control arm or ball joints? what is their performance/ durability?
2002 BMW X5 3.0
2001 v70XC 206K
2002 v70XC 173K
2001 v70XC 206K
2002 v70XC 173K
