O2 sensor testing
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
benweekes
Year and Model: 1999 v70 xc
O2 sensor testing
Post by benweekes »
I have not been able to find a vaccum leak in my 1999 v70xc.So I wanted to test my 02 sensor.I was at FCP yesterday and saw they had a 02 sensor testing unit.It's designed to test the sensor still on the car.Small hand held unit made by I believe "Topco".Basically a positive and ground wire setup.It says hook the positive to the outgoing wire on the 02 sensor and the black to any ground.Start the car and after a few seconds a light on the unit goes if the sensor is working.I wanted to know if anyone is familiar with this unit and if it sounds like a reliable way to test the 02 sensor?
Thanx
Ben Weekes
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Unfortunately it's not really an "all or nothing" sensor- If Lee comes back on he can tell you the exact ohms or amps it should be reading if working properly. I'm just afraid the little tester isn't going to tell you enough.
benweekes
Post by benweekes »
Thats what I was afraid of.Is it possible though to test the o2 sensor on the car or do you have to remove it and do the torch test to get a reliable result?
thanx again
Ben Weekes
