Lessons from 200K miles on a 1994 850 NA
This topic is in the MVS Volvo Repair Database » Lessons from 200K miles on a 1994 850 NA
icelandic
Post by icelandic »
For sometime my 1994 850 NA had been burning oil. Even though power was good, I thought that it might be valve seals or valve guides and kept putting off a head repair job. Until one day, driving at 60mph, engine started misfiring. To make along story short, a small piece of an exhaust valve on Cyl3 broke of. We took the head appart and found that actually the seals were bad. Probably the valve broke due to a piece of carbon build up that got on the way when the valve closed. For an engine this old, running with a 25% ethanol content gasoline, the amount of carbon was comparable to much lower mileage engines. No oil sludge of any kind, cams are perfect, valve lifters are perfect. Very small amount of carbon like material on oil passage ways. Head gasket looked like new. Coolant passageways clear and clean thrughout.
We decided to take pistons out. Oil pan also clean, no sludge, just the brownish varnish like inside. O-rings looked perfect. Pistons look perfect after clean up. Rings appear to be perfect also, although I decided to replace them, since I found some carbon build up on them. Cylinder walls are in exceptional good shape, no visible wear, and still have the polishing markings. No ovalization either. Piston rods and pins look new, as the crank does. Only significant finding was that one of the piston rod bearings had some scratch markings on it that could be felt if one passed the fingernail on it. Water pump, still the original one, has no leaks and no play. Looks new, but I will replace it anyway.
Having taken good care of this car since new, however exposing it to long traffic jams in Sao Paulo with long, extended idling times, I concluded that after we put everything back with new rings, rebuilt head, and new piston rod bearings, and new OEM water pump, it will be good to go for many years more. I was impressed on how wear was minimal.
Icelandic
1995 859 auto NA
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Excellent news! I too have a '94 850 I just bought a month ago- it runs very strong. After probing the ECU for mileage and fixing the odometer gear, I'm at 192K miles- so I'm approaching your mileage of 200K. It's good to know that these cars keep on going. I of course replaced all essential timing components and water pump. I still have some positive pressure after getting rid of the flame trap and cleaning out the EGR.. I'm hoping that PCV clean-up or replacement (previous owner replaced it approx. 55K miles ago), it will run without the pressure. Also have sway bar end links to replace (if my son would get home with it! ha). Anyway, thanks for posting- the way the car runs I would expect all internal engine parts to be in good shape on my 850 as well!
MIJ 8)
dan2286
Year and Model: 94 850 N/A 5 Spd.
Post by dan2286 »
That makes me feel better about buying one with 300,000 miles on it :D
_HighVoltage_
Year and Model: 1994 850 NA
Post by _HighVoltage_ »
Makes me feel good about my 152,000 mile 94NA. I've driven it 1000 miles so far and it doesn't seem to burn any oil. At least for the moment...
volvomileage
Post by volvomileage »
feels great to see that they are really built to last lolll
by the way mij how do you probe the ecu for mileage ;)
thanks
volvo 850 95 sedan non/turbo 185 k
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2854 times
Been thanked: 1332 times
Post by matthew1 »
Also -> Amazon link
Thanks Matt!
matthew1
Site Admin
Post by matthew1 »
^^^ :wink:
(My first instinct is to nag users about not doing a search for things like this, but the site isn't organized perfectly yet, and things can still be hard to find. You and I know if something's there to be found at all. In business it's called "knowing where the bodies are buried.")
Also -> Amazon link
volvomileage
thanks Matt...for the link and for not nagging :P lollll
thumbs up for ur site
cheers !
Matty Moo
Year and Model: 850, 1996
Has thanked: 1 time
Been thanked: 30 times
Post by Matty Moo »
200k is amazing for a car that runs on 25% ethanol and idles in traffic everyday.
http://www.midwest-abs.com
Simplycleanpowerwash.com
1999 s70 Plain Jane.
2000 s70 GLT
2014 Ram
2012 Jeep Wrangler Unlimited
