Idles rough after 20 minutes. No Codes
ejburbank
Post by ejburbank »
I have a 1998 S70 T5. It was my son's car for school. I haven't used it for about a month. I had to jump it to start it and let it idle for about 20 minutes to let the battery charge. After 20 minutes it started shaking and studdering. If I rev it up past 3000 it sounds ok but when it returns to idle it starts shaking. It also smells like a sulfur and garbage mix from the exhaust. I don't get any codes.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1248 times
Post by matthew1 »
Check your air filter and look for disconnected vacuum hoses. Is it low on fuel? Might be bad fuel or junk getting pulled from the bottom of the tank.
Also -> Amazon link
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Sounds very much like a MAF sensor if other things that Matt mentioned check out okay.
Craigd2599
Year and Model: 2007 S40.
Has thanked: 3 times
Post by Craigd2599 »
Smell the fuel tank...does it smell like varnish? When gas sits for a long time it turns bad. If it was your sons car in college he was probably filling it as cheaply as he could to begin with. Could be bad gas.
Craig D
Philly Boy in Lynchburg VA
2007 S40 Previously: 2 850's and an S80
Waiting for that "R" model barn find
