1993volvo850 4 door
- Has thanked: 2660 times
- Been thanked: 1248 times
4 bolts hold it down. They're about 19mm if I recall correctly. Be careful because the nuts are captive and can fall down beneath the floor mount.
Then there's a wire harness or two, and you want to deal with the SIPS (side-impact protection system) correctly so that you don't set it off. You may not have it on a '93. If you do, beneath the plastic shroud that contains the seat controls on the side of the seat you'll see the sensor and a red safety cover to put over it during removal/installation.
