Fuel Filter
daria nelson
Fuel Filter
Post by daria nelson »
Hi,
Can you tell me where the fuel filter is located on a 1994 850?
Thanks!
Daria
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1252 times
Post by matthew1 »
Sitting in the car in the back seat on the right side, it'll be just below you, under the car along the outside 'rail.'
It's a silver or black canister held down by two clamps with bolts/nuts.
Easy to remove. Just have a towel handy to soak up the fuel.
Also -> Amazon link
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
I also recomend that you let your car sit overnight to make sure that there are no hot surfaces you could bump up against. It will also allow time for the pressure to equalize in the fuel line so it is not under high pressure.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
