V70 Headlamps keep burning out Topic is solved
SB Twister
Post by SB Twister »
I have been going through headlamp bulbs on my 2001 V70 about every 3 - 4 months, sometimes even sooner. I have tried several different brands, but the best seem to last only 4 months before filament burn out.
Anybody else experience this problem? Is it commom/normal?
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
These bulbs burn very hot. If you touch the glass bulb the oil on your hand will cause pre-mature failure. When you get a new bulb use a pair of disposable latex gloves to install it. If you do touch the bulb clean it with 95% or better alcohol.
If you have been following the above recomendations and you are blowing bulbs I would suspect the line voltage to be excessive and check that out.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2660 times
Been thanked: 1253 times
Post by matthew1 »
Something's rattling around in my brain about a service bulletin for headlight wiring harnesses on either 850s or S70s... they were causing bulbs to burn out rapidly. I'd call a local Volvo dealer and find out. I tried searching govt. website just now but no luck. :(
Also -> Amazon link
