Computer error code - breather box?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
prienn
Post by prienn »
'01 V70 125k 2.4 non-turbo
We had seen the check engine light pop up several times in the last few months. At autozone, they indicated it was a P0420 code.
Today, we took her in to the dealer to have the recall software updated. They indicated that the crankcase breather system has a lot of pressure and suggested a breather box replacement ($850). 1)What is involved with correcting this? and 2) I'm glad I didn't start replaceing O2 sensors (yet).
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
prienn wrote:'01 V70 125k 2.4 non-turbo
It's a pain, which is why it costs so much.
Before I did that, I would try some www.auto-rx.com in it to see if it will clean up the sludge, hopefully opening up the passages and relieving the pressure. Some people also like Seafoam.
After the cleaning cycle, switch to only synthetic oil to reduce sludge accumulation.
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Actually, it might be a good idea to do the breather box...AutoRx will clean the engine but not necessarily the PCV. I would pull the hose off of the larger accordion hose and clean the PTC nipple/connector out so that it is clear all the way through first and see if this alleviates the pressure.
prienn
Post by prienn »
Does the box get replaced - or is it simply cleaned? Is there a decent write up on this?
Thanks Gents!
vegasjetskier
prienn wrote:Does the box get replaced - or is it simply cleaned?
Either one.
prienn wrote:Is there a decent write up on this?
Here's one for an 850. Your car would be similar.
http://lakesidedp.com/uploadpics/pcv/
