850 t5 wagon '97 Oil out of cap and dipstick
mcbeav
Year and Model: 850 t5 wagon 1997
Post by mcbeav »
I bought a 97 T5 wagon recently with 102,000 miles on it. I noticed oil on the dipstick handle and remembered a problem I had with my old 240, flametrap clogged. Since this model does not have a flame trap I had my mechanic replace the oil trap and related hoses. That being done I do not see any change. It is still blowing oil. Could they have missed anything?
Thanks
jblackburn
Year and Model: 1998 S70 T5
Has thanked: 9 times
Been thanked: 19 times
Post by jblackburn »
Sounds like your PCV system needs to be cleaned. Mine had oil all over the top of valve cover when I bought it. Do you notice a lot of smoke coming out of the tube if you pull out the dipstick handle while the car is running at normal temp?
'98 S70 T5
2016 Chevy Cruze Premier
jblackburn
'98 S70 T5
mcbeav
Post by mcbeav »
I just had the whole system cleaned or replaced and still get positive pressure. The oil trap and the hoses were replaced and they said they cleaned and or replaced the nipples. I am wondering if they missed anything
bw77
Year and Model: 99 S70GLT
Post by bw77 »
jablackburn wrote:http://lakesidedp.com/uploadpics/pcv/
Here you go
Thanks for the link, that's an excellent write-up with great pics. I wish the guy who wrote it had co-authored the Haynes manual!
jblackburn
The only other thing I can think that I've read about is to make sure they hooked up the lines right to the oil separator:
https://www.matthewsvolvosite.com/forum ... =1&t=13999 (about halfway down the page)
Or try running some seafoam through your car and see if that helps it any. I ran this through a Jeep Liberty, and it did wonders for making it run smoother...I have yet to do it to my Volvo, but I would venture to guess that it may loosen up some deposits clogging up your car somewhere other than the PVC.
Maybe MIJ will chime in...he had an 850 that he did everything on, and it still had positive pressure from last I read.
'98 S70 T5
Has thanked: 17 times
Been thanked: 35 times
Post by MadeInJapan »
Yeah...still does I think but I finally got the intake manifold gasket in right so maybe not- haven't checked since yesterday and my son is driving it now....I think that in my case, it's over-filled...so check your oil level- it seems to make a difference...
mcbeav
Post by mcbeav »
Thanks for all of the information. I passed it all to my mechanic and they still can't figure it out.
Oil level is about a pint low or so as oil has blown out of cap and dipstick.
I guess I will try the seafoam and see if that works.
mcbeav
Post by mcbeav »
The Seafoam worked! I poured some in the fuel tank and in the engine. I got smoke out of the tailpipe on a regular basis for a couple of weeks but not now. There is nothing coming out of the dipstick either. I guess it takes a while to work through.
Thanks for the help. The mechanic that did the PCV reinspected it and could not figure anything out. He said I needed a ring job at 102,000. Oil level has remained steady for the last 1000 miles.
FlyingVolvo
Year and Model: 2000 V70XC
Has thanked: 51 times
Been thanked: 73 times
Post by FlyingVolvo »
You did do an oil change soon after adding SeaFoam to the engine right?
2000 V70XC - 340,000 miles
2023 V60 T8 PE
