XC70 2005 How to replace a dipped Xenon bulb?
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
beattie
Year and Model: XC70 2005
Post by beattie »
The bulb to be replaced is the D2R 35W Bi-Xenon dipped bulb on the n/s.The handbook says dealer service item.How do I do this myself? I know that a high voltage is a problem but getting to it seems even more of a problem.
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
XC70XenonBulbReplacement2005.pdf
(73.31 KiB) Downloaded 908 times
beattie
Post by beattie »
Just tried to replace the Bi Xenon bulb on the N/R side,[UK],but didn't get very far because the airfilter housing is in the way !Can anyone help? It should be simple to change a bulb even if it is charged upto 25000volts.The airfilter housing has to come out or I've gotta have smaller hands!So how does it come out asit seems held in by 3 plastic push fasteners-do thes have to be snapped off and replaced?
any help on this would be great.
vegasjetskier
beattie wrote:Just tried to replace the Bi Xenon bulb on the N/R side,[UK],but didn't get very far because the airfilter housing is in the way !Can anyone help? It should be simple to change a bulb even if it is charged upto 25000volts.The airfilter housing has to come out or I've gotta have smaller hands!So how does it come out asit seems held in by 3 plastic push fasteners-do thes have to be snapped off and replaced?
It seems you just pull straight up. Here are directions:
XC70-2005-BiXenonBulbsReplacing.pdf
(436.84 KiB) Downloaded 717 times
