location of code connector 94-940
1975 - 1993 240
1983 - 1992 740
1982 - 1991 760
1986 - 1991 780
1990 - 1998 940
1990 - 1998 960
1997 - 1998 V90/S90
Hobie2
Post by Hobie2 »
I have a scanner & list of codes for the 1994 940 non turbo, but can't find the connector location to hook up code reader. Anyone with knowledge of location, would be greatly appreciated!
George Vrionis
Post by George Vrionis »
Hi
I'm not sure this is what you're after but please read on.
If its anything like my 91 740 (which is the shape of a 940) the diagnostic unit is a little black plastic box, located under the bonet on the left hand side, right up the back of the engine bay, near the identification plate.
I think there are 6 ports, you will be using port 2 for on board diagnosis (scanner not required). I suggest you purchase a manual for the vehicle as this will also include the instructions.
I wouldn't know how to use a scanner (or what exactly it is) but maybe its a case of using the other ports on the diagnostic unit. In this case you will probably require a real Volvo issue manual.
There is a risk that the 740 may be different to the 940.
Good luck
George Vrionis
Sydney, Australia
740 Wagon '91
"Gold Member"
