V70XC, MY2001, Help with A\C Service port cap removal!!!
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
firstbrick
Year and Model: V70XC, 2001
Post by firstbrick »
I'm trying to remove the A\C service port cap. It's the plastic cap located near the radiator that is marked 6Nm. It requires a 22mm socket. Mine just spins and spins without backing off. Any Ideas?
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
You need to put vicegrips on it and PULL while turning counterclockwise. That is the highside valve. Do you really want to add through the high side?
firstbrick
vegasjetskier,
Thanks for the response. I'll give that a try. I want to see where the system presently is at with a set of A\C pressure gauges I have.
