1995 850 Odometer Problem
daveydes
Post by daveydes »
The odometer just stopped working (the speedometer still works). Anyone have a suggestion on what to look for? thanks for your help.
chriskose
Post by chriskose »
Is it the analog or digital odometer?
In the CD player now: Collective Soul
daveydes
Post by daveydes »
odometer is analog.
Guest
Post by Guest »
call your local VDO instuments place, mind went and i took it in thay replaced the gears because one broke, cost me AUS$100 works fine now. volvo tryed to sting me 400 to replace the whole assembly, worth a try.
Pete
daveydes
Post by daveydes »
Pete- thanks for the suggestion. I will try it. But what is a VDO shop?
Dave
fullonloon
Post by fullonloon »
Just leave it and count your blessings :lol:
It will do great things for the value of the car...
JDG
Post by JDG »
a small gear in the odometer unit has lost a tooth- you can
get a replacement gear from www.odometergears.com or from Ebay-do a
search-a guy sells them for $16 + shipping. You can remove the gauge
cluster yourself- T25 screwdriver-check Bay13 at volvospeed on removal
of dash- you can dismantle the cluster with a T10 and a small phillips-
while you have the odometer gear out, set mileage by rotating the lower
gear that rotates the numbers with a rubber wheel on a small motor from
a toy car.You can even get the mileage from port A7 on the diagnostics-
check the brickboard http://www.brickboard.com/AWD/index.htm?id=680941
- It took me six months to find all the information-
an hour to change the gear and reset odometer. If you aren't up to
changing the gear there is a speedometer shop in Austin texas you can
mail it to, but you have to tell him the mileage to set it to.
http://thurbers.net/tim/volvoodometer.html
