electric Seat Troubles
breid95
Year and Model: 960, 1996
Post by breid95 »
1996 960 electric seat troubles:
right track up and back don't work driver or passenger.
Nothing blocking the tracks. I got 2 more seats from junk yard, passenger leather perfect condition shows now wear at all
so thinking motors, cables look good, all other functions work excellent. Really strange that 4 seats and all have the same exact issue. right track does not work . thank you for the help in advance breid95
danr960
Year and Model: 964 1994
Post by danr960 »
This may help you, a very common problem with Volvo seats in the 900 series.
https://www.matthewsvolvosite.com/forums ... =2&t=11973
DanR '94 964 343,000 miles (109,000 on the new engine)
breid95
Post by breid95 »
interesting, piece of coat hanger, I would never have thought of that one, I will try it. Do you remember how many inches you used? thank you ever so much
danr960
Post by danr960 »
Not sure, maybe 3/8". I did some measurments of the cable, sheath and the hole of the motor shaft to get to the proper length.
DanR
breid95
Post by breid95 »
:D :lol: :)
Dan R you are a genious. i resolved the right track cable issue with a 10cm very small piece of coat hanger. I could have used 15cm. can't believe volvo would use too short a cable. I bought 2 new cables 13.00 each and still wouldn't work until the piece of coat hanger.
thank you for coming to my rescue. breid95
billofdurham
Year and Model: 855, 1995
Been thanked: 5 times
Post by billofdurham »
Thank you for the update which helps others who have the same problem.
Bill.
Previously:
1984 244DL, Manual, Beige.
1987 744GLE, Manual, Green.
DeRail
Year and Model: None
Post by DeRail »
Aha! Just the people I need to talk to :)
I finally took the plunge, clipped the hog rings at the bottom of the seat, pulled the leather up and checked the cable running to the right gearbox. I couldn't feel the cable spinning inside the sheath, but if I angled the cable just right, I could feel it trying to catch on the transmission end. I tried muscling the cable back into the motor temporarily to see if it would move but I didn't want to round off the square end so I let it be. If you could advise on how exactly to do the hangar trick and if it would work that would be GREAT!
Thank you,
Darrell
