2001 S80 - Anyone tried DIY replacement of transmission?
dcarlson12
- Year and Model: 1997 850 T5
- Been thanked: 2 times
Wonder if you could obtain one from a wrecker and then have it rebuilt by a good tranny shop who hopefully could upgrade some or all of its weaker points?
Eg see this site re known problems with this particular GM tranny:
http://www.tripleedgeperformance.com/4T ... n_Info.php
vegasjetskier
- Year and Model: 2010 Toyota Prius
- Been thanked: 6 times
I suppose it could be done, but you will need some special tools, a helper(s) and a lot of room. You have to lower the trans/engine/subframe combo out the bottom of the car and then separate them. I'm going to drive my car until the tranny fails (hopefully never), then evaluate if it's worth paying a shop to replace it for me or junk it and buy a new car.frnorke wrote:Has anyone tried to replace the transmission by themselves? With the failure rate, I want to get another transmission so that I have one when the currently installed one goes.
Crito
These GM trannies have been extremely reliable, in every other car they've been used in. So question is what's the difference when it's in a Volvo? Some people say Volvo messed with some holes and screwed it up. Some people say it's the TCM software. A Volvo master tech on another site says the marks on the dipstick are wrong, and he's got high mileage on his original tranny to prove it -- think he said to measure about four inches up from bottom of dipstick and scratch in a new cold fill line, but don't quote me (google it yourself).
I think the problem is even simpler than all that though. The method used to check fluid level for every other Volvo (RWD and AWD) is with engine off. If you check fluid level of my FWD GM tranny with engine off you'll be a quart or two low. But AFAIK Volvo doesn't specify different procedures. So could be everyone is driving around low on fluid and that's why they're failing prematurely.
Anywho, GM recommended procedure is: wheels chocked, engine on, gear selector in neutral.
- Has thanked: 17 times
- Been thanked: 35 times
Actually, VADIS shows to check the levels on a Volvo at the high end/mark of the dipstick after 30 mins of driving and after going through all of the gears for 10 seconds or so and ending up in Park (with the engine running). The low mark is unreliable according to just about all mechanics I've spoken with. On a AW (Volvo) transmission (not GM), I have always done this when topping off, etc. and never have had any transmission issues from low or otherwise over-filled ATF.Crito wrote: The method used to check fluid level for every other Volvo (RWD and AWD) is with engine off....
dcarlson12
To MIJ:
You say: "The low mark is unreliable according to just about all mechanics I've spoken with."
Are you saying the low mark is too low or too high as shown on the factory dip stick?
Would the 'Full' mark then also be proportionately too high or too low or correct?
Thks,
Dwight
Thks,
Dwight
dcarlson12
To Crito:
What did you google to find the bit about mark being at incorrect place on dipstick?
What was the website where you found this?
Thks.
Thks.
vegasjetskier
As MIJ said in a post above: "Actually, VADIS shows to check the levels on a Volvo at the high end/mark of the dipstick after 30 mins of driving and after going through all of the gears for 10 seconds or so and ending up in Park (with the engine running)."frnorke wrote:Actually, could someone provide the correct way to check the transmission fluid level on a 2001 S80? I think I've been doing it wrong all along.
V/R,
Kurt
This is the correct procedure. Do it on a level surface.
Yes, and Yes!!!!vegasjetskier wrote:This is the correct procedure. Do it on a level surface.
- 4511 Views
Last post by wizechatmgr
- 52 Replies
- 12461 Views
Last post by mecheng
- 3006 Views
Last post by MadeInJapan
- 13 Replies
- 4394 Views
Last post by Peter V70
- 33 Replies
- 11117 Views
Last post by bmdubya1198
