MY S70 T5 WORK FINE FOR +- 5KM THEN THE TRANSMISSION NUTRALIZE AN THE CAR DONT MOVE IN ANY DIRECTION Y LEAVE FOR 10 MUNUTES A STRAT AGAIN A CAN DRIVE +- 5KM A THEN NEUTRALIZE AGAIN
WHAT CAN BE HAPPEND
SORRY FOR MY ENGLISH
98 S70 T5 TRANSMISSION PROBLEN
- Has thanked: 2660 times
- Been thanked: 1253 times
Check your trans. fluid level, color and smell. It should be orange or pink, with no burnt smell.
https://www.matthewsvolvosite.com/images ... ne_bay.jpg
You may want to change the fluid if it fails any of these tests, but it sounds like your transmission is failing.
THE COLOR IS OK BUT THE SMELL IS LIKE A SMOKE
WHAT CAN I DO IS MY TRANSMISSION FAIL HAVE A REPARATION KIT???
OR NEED TO CHANGE FOR A NEW ONE
I HAVE A 1995 850 TURBO CRASH ONLY IN THE LEFT SIDE I CAN PUT THESE TRANSMISSIO IN THE S70?? IT'S ONLY A QUESTION???
ARE THE SAME TRANSMISSION???
Change your transmission fluid first. There is a chance that will give your transmission more life.
If not, then look closely at a transmission swap. Mechanically I believe they are the same. Electronically -- I don't know.
