Change a Tire??
2001 - 2007 V70
2001 - 2009 S60
2003 - 2007 S60 R
2004 - 2007 V70 R
caseyc
Year and Model: V70 2001
Change a Tire??
Post by caseyc »
I may not be the most mechanically inclined, but i was pretty sure I could change a tire...until now.
My 2001 V70 has a flat rear tire. I removed the five lugs but it isn't coming off. I took off the cap in the center but there is no bolt behind it....just a flat circle.
Is there another bolt behind that thing in the center which appears to be solidly jammed in there? I have chiseled away at that but I don't see any movement there.
What am I missing here?
vegasjetskier
Year and Model: 2010 Toyota Prius
Been thanked: 6 times
Post by vegasjetskier »
Hit the edge of the tire in toward the center of the car with your hand or a rubber mallet. The wheel is probably just rusted in place and you need to break it loose.
