940 turbo '95 passenger side mirror glass shakes
cquarts
Post by cquarts »
while driving the passenger side mirror shakes enough to make you seasick. the actual glass mirror doesn't appear to be overly loose inside its housing. any help? thanks in advance.
fharen
Year and Model: 1994 960
Post by fharen »
My 960 1994 Drivers mirror does the same thing.
Doesn't appear loose in the housing and doesn't flex or rock when its pressed upon anymore than the passenger side.
anotherskait
Year and Model: 92 940 turbo
Post by anotherskait »
My `92 was doing this recently. If you push on it, it feels fine, but if you take something and hook it behind the mirror it will pull away from the backing plate. I took some clear rtv sealant and coated the back of the mirror, pushed it against the backing plate for a couple minutes til the rtv was dry, and haven't had a problem since.
