clunking sound over bumps?
mko
Post by mko »
I drove a 93 850 yesterday... when going over bumps, there's a noticable clunk clunk coming from the front suspension area (& perhaps the rear ... I can't be sure... but it was probably just from the front). I couldn't pinpoint the noise, and the suspension doesn't feel at all loose.
I tested it by doing tight circles w/ the wheel fully turned one direction & then the other - no problems there... only this clunking/rattle over rough roads.
The steering feels a bit loose, but tollerable - any thoughts? This is pretty much my only hangup before buying the car.
The salesman told me that it could be the rubber(?) bushings around the tie-rods, but I don't know...
any help would be greatly appreciated.
93 850 - 141K
mko
Post by mko »
He had it checked out by his mechanic & supposedly it's a bad ball joint... and is quoting $250 for the repair... this sounds about right doesn't it?
I assume there is a ball joint on either side - correct? If both are bad, is that $500?
thanks.
- mko
mko
Post by mko »
some more info:
the car was donated to a charity that is in the business of fixing up & selling donated vehicles. In this case, it was a car whose timing belt appears to have broken... they did a good amount of engine work and is now reselling the car.
some sticking points.
1. Noise from the struts - if it's only $250, why not fix it.
2. car is listed as a 94 w/ 130K... it's a 93 w/ 141K
3. no records except from the work that was done after donation.
i don't know if i should just walk away or try to work w/ him... basically we're talking $4100 out the door (tax, etc) might be a bit high.
matthew1
Site Admin
Year and Model: 850 T5, 1997
Has thanked: 2664 times
Been thanked: 1256 times
Post by matthew1 »
The car's not worth it. Walk away.
Also -> Amazon link
mko
Post by mko »
matthew1 wrote:The car's not worth it. Walk away.
thanks - that's what I think I needed.
mko
Post by mko »
thanks for the advice!
I found & purchaced a 93 850 w/ 88K in far better condition for the same price!
matthew1
Site Admin
Post by matthew1 »
Good. Now make sure the timing belt has been changed, same for transmission fluid, air filter and spark plugs.
Get to work!
Also -> Amazon link
mko
Post by mko »
matthew1 wrote:Good. Now make sure the timing belt has been changed, same for transmission fluid, air filter and spark plugs.
Get to work!
right o.
timing belt was changed @ 65K... I'll check the rest.
the mystery whine has returned :(
Tsquared
Year and Model: 11 C30
Has thanked: 1 time
Post by Tsquared »
Also get a Chilton or Haynes service manual. It has some good information on what needs to happen service wise and how to do the procedures. Volvos have a rep for running many miles, IF they are properly maintained. Many of the things the dealer or INDY shop charges big bucks for can be accomplished at home with basic tools.
Congratulations on your car.
'11 C30 T5
'96 854 - died an early death with 184K miles. Killed by the front end of an LTD on a suicide mission (T-boned and both cars totaled).
mko
Post by mko »
Tsquared wrote:Also get a Chilton or Haynes service manual. It has some good information on what needs to happen service wise and how to do the procedures. Volvos have a rep for running many miles, IF they are properly maintained. Many of the things the dealer or INDY shop charges big bucks for can be accomplished at home with basic tools.
will do - thanks for the advice - I'm looking forward to learning more about car repair... thanks!
